Help Needed in Removing The DashBoard..!!
raghubhaskar
Albany, NY
Hi guys, I need instructions on how I can remove the dashboard on my 2006FX35. There is a post here for a 2004FX but the consoles are different. I have a PA15NIS installed in my car and now I need to make some more mods to it but I am not able to figure out where to start from.
Also would someone happen to have a Workshop manual for FX?
RB
when u say dashboard u mean the radio dash?
if thats the case i have a 2007 dont know if they are much different..but all you do is pull off the outer casing they are just clips so they will pop out and that will expose the navigation screen..be gentle but firm when you do it there are no screws that hold it in the 2007..hope this helps..
for the center console i would think the idea of taking it off is a general and a similar one to the earlier model year. just have to be patient, gentle and start from the shifter panel.
Thanks Guys, now i am wondering where they kept the iPod adapter. The cable comes from the passenger glove compartment. I just need to access that part. So I would need to remove the glove compartment. So I do not need to go thru the center console right?
RB
im assuming you already have the unit connected to the back of your system so then you would just have to go through the glove...i dont think you need to go through your center console unless your trying to run the wire to there and hook up the ipod at that point..then you would have to and i can help you with the center console if thats the case just let me know..
sorry cant send pms yet..
ill have to look again been a year since i did it but its pretty straightfoward just remove all the scrrews.gimme a couple days and ill look at it for u
RB[/QUOTE]
