Help me pls
TEGI
INFINITI FX35 2008 4WD
Tengo
Hello,i need a help i have infiniti fx35 2008 4WD .. want to change automatic transsmision oil.. i dont understand do i have to change or not.. help me guys pls my car runs 125800 killometers..
Thanks mate.. others said that if i change fluid it will damage transmission..is it wright? I am afraid i dont want to damage..and what kind of transsmision oil need my infiniti fx 35 2008 4WD? And How many littre?
Today i drive littel bit and when i came home i checked again after warm up the car and the level was liked this
Hu..looks like engine oil.Not transmission oil! Check ur transfer case..Did u fill 4 to 5 quarts of tranny fluid? Check for leaks under your FX!
i have infiniti fx 35 2008 4x4 want to change transmission fluid there is a photo my transmission oil color.. what to do change or not? Iam afraid my friend said to me if i change it will damge transmission and it will slip :(
It might damage it. That oil doesn't look good and like Dragon wrote above, it looks like engine oil.
If I were you, I'd pull the trans pan plug and drain it into a clean container with the thought of possibly reusing what you drained. Then I'd drop the pan and take a look at the 2 magnets attached to the bottom of the pan.
If the bottom of the pan is decent and the 2 magnets have very little material on them, I'd;
put it all back together, add back all the trans fluid you pulled out, pull the plug again, drain the 3-4 quarts that will come out from just a plug pull and then refill it with new fluid.
If the bottom of the pan looks like :poop: and the magnets look like :poop:, then the trans may very well be :poop: and it's a roll of the dice as to whether or not the trans can take new fluid. At least you've got all the old stuff to add back in.
If you recently bought this FX, I'd verify whether that trans oil is in fact trans oil 1st cause that shit looks like fuck'n engine oil. Smell it. Taste it. Pour some on the floor and roll around in it. Become one with the oil. Let it speak to you. Make love to it. Get all up in that oil and make t your bitch. :rofl: Only then will it reveal it's true nature, only then will you know if this is in fact trans oil and not engine oil that some ignorant jackass put in your transmission. :eek:
If the vehicle has 125k kms (75k miles) the oil may be burnt - which means that it may not necessarily be engine oil.
To the OP, the tranny oil is red. Use only Nissan transmission oil.
Guys i did today transmission oil change and eveything works good.. is it possible after that heppens anything bed??
