Help me find good D2S 6000k bulb.
sobi6111
Kazakstan, Aktau
Does it matter what brand to buy D2S bulb? 10$ ones or 200$?
i am currently having OEM 4300 and want to match to my fogs 6000k. Fogs have cheapest h8 possible,and works nice :-)
Any suggestions? What brand to get D2S to be the brightest 6000k bulb possible and not 1000$ ones :-)
This is your best aftermarket 6000k D2S bulb. I've tried a lot of ebay/cheap kinds and Morimoto is my favorite -- almost comparable to Philips.
http://store.theretrofitsource.com/...d=127&osCsid=27fc2e3a8c55db3906584f6543773660
I also agree that Morimoto is also a great replacement. Ive been using the same pair from the retrofitsource for 1.5 years now with absolutely no problems. Fast shipping also. Light output is indeed pure white with a hint of blue.
GL!
edit: retrofitsource also has philips 6k bulbs in stock for $150. If your willing to shell out some more $, cant go wrong with Philips :)
http://store.theretrofitsource.com/...d=180&osCsid=27fc2e3a8c55db3906584f6543773660
Ordered Philips 6000k d2s bubls from eBay for 80$ :-)
hopefully they work good.
Are they fake Philips? as same cost 150$ from others?
That's really cheap for philips 6000k bulbs, as they are normally $200 and right now on sale for $150.
If they are real, what a heck of a deal!
Guys can i just order D2S Xenon Bulbs or do you order a complete kit. Cannot find bulbs that fit our lights here in the netherlands. Only kits so wiring is needed. But having oem xenon there must be a way to just order new 6K bulbs.......
Ray, You only need the D2S BULB for your headlights. The full kits are used to retrofit the foglights with HID.
You should be able to go to any store that sells HID and they should be able to provide you with just the bulbs.
Ok clear i will try to surch a little bit harder :tup:
