Help - Car Shuts Off While Driving!
I strongly recommend going behind the glovebox and scrubbing/treating the ECU main ground point. I found mine to be corroded. I cleaned/treated it and a lot of gremlins vanished.
The fact that you're not getting codes tells me it's an ECU problem.
Question...What is ECU? I'm asking because I'm having the same issue with my '03 FX35
Interesting point. Thanks for sharing. Where exactly is this ground point behind the glove box? Have any pics, illustrations or links depicting this location?
You'll have to remove the glovebox. Squeeze the walls together and it will pop out.
You'll have to push a module up out of the way to access the ECU ground point.
It won't hurt it.
