Hello Everybody
twanger
Im new to the infinity scene.
I just bought my first FX45 its an O# with 87 0000 miles
1 owner car
lots of service records. I see that there were a lot of fluid changes both diffs. case brakes were flushed coolant flushed as well
I changed oil and filter- Air filter and Cabin filter - Changing the plugs next weekend. What is best It has less exspencive NGK the OEM NGK in the car Or should I put Dens o plugs in it
What else do I need to Change?
Fluids
I'm considering changing the coolant and rear diff fluids too. Sounds like a mess but I'll have the right fluid in there.
Does the plastic engine belly pan have to be removed to get at the radiator drain plug?
Looks like I need a 10mm hex wrench for the diff plugs?
Thanks,
Bob
yes you will need to. it's relatively easy. Welcome to IS Twanger. As long as you follow the owner's manual, you need not worry about a thing.
