Hella Supertone Dual Tone Horn Kit
Status
Not open for further replies.
B2autodesigns
2008 FX35
Hello Guys,
Got a ton of these in stock.
Hella Supertone Dual Tone Horn Kit.
Hella Supertones are the horns to have for getting the attention of other vehicles on the road. Hella uses a combination of low tone (300Hz) and high tone (500hZ) disk-type horns to project a powerful 118dB sound that is designed for highway use. Hella includes the two 12V Supertone horns each with a mounting bracket, a relay and wiring instructions.
Specs:
Nominal Voltage [V] -------12V
Wattage [W] -------------72
Frequency [Hz] -----------300 Low-Tone/500 High-Tone
Torque of Bracket [Nm]----10 - 15
Sound Level [Db (A)] -----118
Weight [Kg] --------------0.42
Amperage [A] ------------5.5A
Mounting -----------------Bracket
Housing ------------------Black Coated Metal w/ Red Protective Grille
Connection Type ---------2x 6.3 mm blade terminal contacts
Feature ------------------83 mm Bracket
Link to pricing:
http://www.b2autodesigns.com/product_info.php?products_id=3866
Youtube link: stock vs Hella
YouTube - ‪Stock RS horn vs. Hella Supertones‬‏
Got these on my own car and love the sound. Not to loud, but loud enough. Very easy to install. Replaces the stock horns.
Thanks
Charles
813-787-4075
cback@b2autodesigns.com
Direct hook up, no relay? If no relay on the FX I'd be in for a GB......Had these on two of my previous rides and and I loved them, people HEAR you coming.
If it is the same as the G35/350Z no relay needed. I didn't use a relay on my project car, but mine is a Mitsubishi
Huh, didn't listen to the clip, sounds different than mines did. Wonder if it's a recording issue.
Sounds like an upgrade for the subaru, but I like the sound of our Infiniti horns better.
sounds like a cheapo horn replaced with a cheapo horn that just reached puberty. I'll stick with the Infiniti horn.
Status
