Today i was replacing both headlights... as a noob my self i have seen many threads here
that explains how to take bumper out but nothing about removing/replacing headlights...
please feel free to add comments ....this is my first write up so it may be confusing...
i bught new headlights bcuz the old ones melted dueto bad dtrl swap.... all my fault...
in this DIY you will see alil bit of how to take GRILL OUT/BUMPER OUT/HEADLIGHT OUT/ DTRL SWAP/
AND LIGHT BULB CHANGE.... LOL
none of thes mentioned DIY,S are my creation... they are created by other members in IS COMMUNITY
I AM JUST ELABORATING AND TAKING MORE PICS FOR A BETTER UNDERSTANDING... PLEASE THANK IS!!!!
1- take the 6 clips out of the grill...
2- the grill is now free but there are 4 clips that are attached towards the radiator thay you use
a plier to take out.... close up of the clip...
3-the holes were where the clips were held in place to the bumper.
4-the headlights are held by 4 screws. 2 on top and 2 at thhe bottom... one behind the front bumper
and the other behind the wheel wells.
5-to remove the bumper you will have to remove 10-15 bolts depending on how many you have under the car
by the bottom plastic cover... but you have to remove 2 screws that hold the bumper to the fender...on each side..
hard to get a nice pic so these are some supporting pics..
6- once you unbolt these 2 bolts then you will see that the bumper will kinda wobble... they are still
held in place by 2 clips right under the headlight housing... if you pull the bumper you will see them.
7- when pulling on them be careful i broke 1 of the clips but when putting them back in i found it
not to be bi issue with just 1 clip instead of 2 but still be careful...
8- with the bumper off or hanging by 1 or 2 screws at the bottom... you can now access the bolt under
the headlight. this shoul be the last bolt to remove... unplug all th electrical harnesses/wiring...
take em out gently...
9- once you take the headlights out you can now exchange the ballast (3 screws) held in under the headlight.
and the light bulbs..(unclip the metal pin and take the bulbs out..
this is the ballast ( i didnt know until today)
now take the silver holder out by twistin like a reggular bulb
you will see the rear side of the bulb
unclip thes metal sprins by pushing them with your thumb n finger n open the latch....
10- do it to the other side and put the bulbs and the ballasts back in .....
11- if you are going to do DTRL SWAP now is the time .... cut the black wire cover tape
12- i used a nipper to cut the tabs because i was lazy...
13 - please refer to dtrl swap thread for more info if you have any question.
14 - put headlight back in and connect all the wires
15 - put the bumper back in .....
16 - PUT GRILL BACK IN AND CHECK THE LIGHT TO SEE OR OF THEM ARE WORKING WELL CLEAN AFTER
YOUR MESS AND FEEL GOOD DONE!!!!
:mad.:
:mad.:
