Not to sure if this thread is for all mirror inquires or just dedicated to the first posts problem. Anyways, my previous 12 premium maxima had a tilt down feature that tilts both the driver and passenger side mirrors down when i put the car into reverse...does a 12 "base" fx35 have this feature also? My mirror only tilts down depending on which side the switch that controls the mirrors are left at (ex: if i was to adjust my driver side mirror, I would first need to switch that lever located to the bottom right of the steering wheel right to the driver side mirror position, I would adjust it so and leave the lever still on the driver side. Put the car into reverse and only the driver side will tilt down...vice versa...however, if i leave the lever in the neutral position, neither the driver side or passenger side will tilt down). Any help is appreciated. Cheers.
This feature works just the way you described it. It is only meant to help you parralel park, so if your backing in to to a spot on the drivers side you would flip the switch to your left side so the drivers side mirror will tilt to assist you on that side. Vise versa with the other side. The middle position for the switch is the neutral position, no tilt.
---------- Post added at 06:10 PM ---------- Previous post was at 06:08 PM ----------
^^^Yes I think all FXs do this. You choose which side tilts. Both don't tilt at once.
As for shaking mirrors...
Mine are driving me crazy, I still haven't tightened them
I don't think the 1st Gen has the tilted mirrors feature. If it did, I never noticed it on my 06 or 08.
