Halo/Custom Headlight Help!
Ill call dealership today and ask if that's the d1s bulbs they use. If it is ill get the d2s version. They wouldn't need any modification or anything right? Just plug the bulb in and go?
I would go with 6000k myself if you want pure white with a small hint of blue the GM products have, also keep in mind they will go from bluish to white overtime with burn in.
Escalade bulbs are not 6000k, they are either 4300k or 5000k. The FX projector is also diff than the escalade projector so it won't look exactly the same.
I think it's just part of the mold from their manufacture. It does not affect anything. Once you install, you'll see - the cap goes back on just fine and the lense sits flat.
No no no. There is like a piece of riveted glass on the raised part of lens. Will take pictures later to try and show what I'm talking about
---------- Post added at 02:39 PM ---------- Previous post was at 02:35 PM ----------
See? I tried to focus in on it but its on the left side
I'll have to look at my lenses when I get home. I don't remember any rivets. I remember there being a section that has raised ridges right where you're showing, but it wasn't riveted.
So what are the size rings? Do you have close up pic of the headlights with rings off? Wanted to see fitment over the shroud.
Thanks for the pic Dave. So I take that you don't have any problem with the ring being too thick that it bump against the lens as John (TurboCad) mentioned? I have these rings seating in my basement and have not had a chance to install them.
