gtspec Rear Lateral brace install
Hanzofx
Westchester, NY
2008 fx35 awd
Hey fellas, Im in the process, of installing gtspec bracing kit. Everything is going on pretty easy except for the rear lateral brace. The driver side mounted up perfect the H bolt didnt even move. However the passenger side not only move seems to be getting lower, and futher out of wack the more I try. Any ideas? Im gonna end up needing an alignment.:iS:
Was the FX jacked up when you loosend the nut and did you match mark it's location before loosening?
If it was not jacked up maybe the weight of the vehicle on the suspension was messing with you.
If the alignment nut/washer moved then you should get a realignment. Did you hold it in place when you removed the passenger side nut?
yeah if the washer moved at all it needs to be realigned. mine both moved the exact same amount so they both got thrown off evenly..im getting an alignment soon
but it literally took 15 minutes to install both rear braces
