Does the engine cover just pop right off?
yes no bolts
yes no bolts
Grab it on both side and lift up using gentle upward force to loosen the two push pin clips in the frontal part of the cover. Once the front part is loosen, pulling it toward the front of the car to release the two rear clips.
just pull up from the front. It won't break. That's how you remove it.
Also try not to yank slowly hard. I think the secret is to pull hard very quickly up. When you go slow hard may feel like you are bending the cover more than needed. Also I would put both of your hands at the front of the cover not the sides when pulling up.
You will pull up fast and quick to get the front loose and then pull towards you to slide out the rear.
