GT SPEC Mid chassis ladder brace Feeler - GB
Status
Not open for further replies.
Thanks Ege I was looking for the same thread so I can explain lance where the brace mount points would be at in conjuction with the 4 point brace.
Thanks for everything I got the package bro.. Looks great!
Thanks Rubare-BTW-On the brace item numbers I meant GTS-SUS-1131 4pt. mid ladder and GTS-SUS-1321 4pt. front ladder, you got it anyway-cool.
Got you bro.. Before I started this thread I was confused about the placement of the brace.. I looked at ege's thread and I was kind of getting it. Then I did my lil own research plus lifted my fx couple of time to visualized it and I got it.. That's why I think that in combination with the rest of the braces it will enhance the FX's performance..
Def can't wait for this.
guys I got a reply from GTspec.. They said the mid chassis braces are on their way. So they are jus waiting for the shipment to arrive so they can start the testing of regular 350Z brace on the FX so they can see which changes they have to make to it..
I adressed the AWD and RWD differences (diferential case is that IT? right?) so if I didn't do it right please do help me out and adress it.
Someone from GTspec will elaborate more about the situation and from my view of things project have a 98% chance of happening so we will get hooked up with FX's mid chassis ladder braces..
Yeah!!!!!!
I guess I'll throw my name into the hat for these...and offer up my FX for fittings if needed. Thanks for the update Rubare!
1. Rubare
2. gto
3. turbocad6
4. hanzofx
5. HumbertoCALI
6. aiya
7. White_Hair
8. BaBaLuwee
9. HYME
10. gchristopher9
11. Logan
12. aiya
---------- Post added at 05:06 PM ---------- Previous post was at 04:53 PM ----------
*sigh* Soon just pointed out that I am on the list twice...hahahaha
Ooops....I don't think I have a need for two.
1. Rubare
2. gto
3. turbocad6
4. hanzofx
5. HumbertoCALI
6. aiya
7. White_Hair
8. BaBaLuwee
9. HYME
10. gchristopher9
11. Logan
=P
Yeah no problem man. I'm really glad this is heading the right direction. Hopefully Another sucessful GB from GTspec..
Well one more update. GTspec got the mid chassis ladder brace and they will start testing it out on the fx and see what modification needs to be done. They will let's us know within a week or so.
add me to the list!
1. Rubare
2. gto
3. turbocad6
4. hanzofx
5. HumbertoCALI
6. aiya
7. White_Hair
8. BaBaLuwee
9. HYME
10. gchristopher9
11. Logan
12. Chinke82
usually GTspec requiered 10 or more for a GB i think we have enough and more.. keep it coming guys.. i hope they let us know more about this project soon..
Do we know how hard the install we be? i'm guessing pretty straight forward bolt on right?
1. Rubare
2. gto
3. turbocad6
4. hanzofx
5. HumbertoCALI
6. aiya
7. White_Hair
8. BaBaLuwee
9. HYME
10. gchristopher9
11. Logan
12. Chinke82
13. jumbosrule
1. Rubare
2. gto
3. turbocad6
4. hanzofx
5. HumbertoCALI
6. aiya
7. White_Hair
8. BaBaLuwee
9. HYME
10. gchristopher9
11. Logan
12. Chinke82
13. jumbosrule
14. The fx 45 beast
1. Rubare
2. gto
3. turbocad6
4. hanzofx
5. HumbertoCALI
6. aiya
7. White_Hair
8. BaBaLuwee
9. HYME
10. gchristopher9
11. Logan
12. Chinke82
13. jumbosrule
14. The fx 45 beast
15. myl168
yep.. i think beside the STB brace this one will be the easiest..
I think the front mounting point will require a rivet to be able to use that chasis hole. If I've identified the points correctly last time, the front holes are too big and irregular shaped for a direct bolt on.. I guess, we'll learn about that soon..
Awesome.. Thank you Adam..
I'm setting this GB up and it would be messed up if it doesn't happenned. Lol
Keep us in touch if you talk to them again.
PM sent.
ok, we got the FX on the lift, look like the mid chassis required modification to fit on the FX.
We will have the brace mock up next week (help from Logan from RPMNYC).
Two of the mounting points required a chassis rivet (like those on the front engine brace), and the other two are stock bolt / mounting points.
The two mounting points that required chassis rivet also required drilling, need to enlarge the holes by about 1 to 2 mm.
We have to extend the brace about 2" to 3" since the FX body are wider compare to the G and Z.
But yes, the project is going forward and prototype brace will be done in 1 to 2 weeks.
Mark.
GTSPEC
Status
