FX45 Gas station pump trigger lock doesn't stay locked
Discussion in 'FX (03-08) - Engine & Drivetrain' started by money042, May 17, 2017.
  1. money042
    money042 Member
    63
    Orange County, CA
    2008 FX45
    Recently, when I'm pumping gas, I can't get the trigger to stay locked. The gas will pump for a few gallons and the trigger lock will pop like it's full. I'll squeeze it again and it'll pop again after a few seconds of pumping. I have to hold it just right, or else the trigger will pop and stop pumping. I only get gas at Costco (on my commute and least expensive of all stations around me). I haven't tried any other gas stations yet. Anyone know why this may be happening? (I don't have any issues with my Nissan Quest at Costco or other stations)
    on a side note, my FX has an issue with reporting fuel level. I can pump it all the way full, and when I start the car, the fuel gauge will not show 100% full, more like 5/6 or 7/8. This has been going on for years, I've learned to live with it. Not sure if the two are connected.
  2. shadow191
    shadow191 Premium Member Premium
    4,077
    310
    Atlanta, GA
    2007 FX35
    The pumping gas issue is pretty common with the FX and G/Z. I think there was a recall years ago on this, something to do with the fuel filler. When it happens, I just turn the pump sideways and it will keep going. Some have to turn the nozzle upside down.
  3. matrixx860
    matrixx860 Ghost Rider Premium
    2,369
    29
    Wolcott, Ct.
    2012 Nissan Maxima SV
    Joey
    Don't put it in all the way and fill it at a tilt. I had the same problem with my fx.
    Sent from my SM-N920V
  4. DatMan
    DatMan Member
    496
    85
    Ottawa, ON
    2007 FX35 AWD
    Dat
    I find some pumps are more finicky than others... If I use the far left pump at my nearest COSTCO gas station, it doesn't stay locked... The farthest to the right has absolutely no problems... And I rarely ever have the problem at any gas stations other than COSTCO...
  5. g0ldm4g3
    g0ldm4g3 Would ya just look at it iS VIP
    5,636
    130
    Richmond, TX
    2006 FX35 RWD
    Nnaji
    Weird.. Same thing at my Costco lol
    Sent from my SM-G935T
    DatMan likes this.
  6. Old Blue
    Old Blue Member
    219
    36
    Spring TX
    FX 37 rwd
    Tom
    [on a side note, my FX has an issue with reporting fuel level. I can pump it all the way full, and when I start the car, the fuel gauge will not show 100% full, more like 5/6 or 7/8. This has been going on for years, I've learned to live with it. Not sure if the two are connected.[/QUOTE]
    My 2003 had the same issue. I just lived with it. It started about the same time as when ethanol got added to all gas, 10% ethanol = 10% worse gas mileage on an '03.
    I just reset the odometer when I'd fill up, that seemed to be pretty consistent.™
