FX45 - high flow cats or test pipes?
Hi all,
I've been searching the last little while for a definite answer and can only seem to find information for the fx35 not the fx45.
I have a 04 fx45 v8 - I would like to know which option is available to me. Are there test pipes for the fx45 or are there high flow cats?
If yes to either, can someone name a brand or some options so I can move forward with purchasing. If anyone has past experience, feel free to share. All the best!
so far I have done my research in regards to the kakaumei y pipe however that is quite expensive...
J
The 03-05 FX45 should be the same (I assume). They modified the cats for MYs 06-08 in the 45.
Test pipes are just, pipes..... How loud do you want to go? If you pick up a decent pair of 300 cell cats you will still have a bit of sound dampening with plenty of flow. What exhaust are you running?
Right now just flowmaster 80.........yea i think id like to get resonated pipes or some high flow cats for better AIR FLOW and no rasp. any best bang for buck reccomendations on which and where to buy?
kept the resonator on cus didnt want the dronage
Good call on resonator, checking on cat manufacturer now.
Logan, thanks bro.
side note: u from seattle? I go down there from time to time cause im from Vancouver! Love it there.
I also go there for this even called FreakNight lol its awesome..
---------- Post added at 02:45 PM ---------- Previous post was at 02:44 PM ----------
RTp are a good choice over just race/test pipes
thx bakes. Ive actually followed your threads since i first joined IS.. not all but I've seen your fx's ..killer.
---------- Post added at 02:45 PM ---------- Previous post was at 02:45 PM ----------
thx bakes. Ive actually followed your threads since i first joined IS.. not all but I've seen your fx's ..killer. need to know where to get RTP pipes tho...for good price.
rtp = resonated test pipes. they are like regular cheaper test pipes, only they are packed usually with fiberglass. I think most members buy Berks
Will these fit my 2004 Infiniti FX45 ?
http://www.conceptzperformance.com/...&Car_Type=350Z&UID=2014020622485766.249.73.37
Please let me know thank you!
---------- Post added at 04:21 PM ---------- Previous post was at 04:20 PM ----------
Hey Logan,
Will this fit my 2004 FX45
Do what I did - look all over the z/g forums and you'll find a deal.
Sort of.. they are test pipes with a resonator on each one...
They should, but keep in mind that resonated test pipes will rasp. They just have less rasp than non resonated test pipes. They will still be louder than HFC's because HFC's have actual catalytic material that the exhaust gases have to flow through. This cuts a lot of noise out. The resonator in most test pipes is very small and it's still a straight through pipe with perforations on the side for some exhaust to go through.
Hey Logan,
Not sure on exact fit, hate to make the call. You can always slice and dice, it just gets more expensive.
still looking for a y pipe thatll fit my car.
Megan racing V2 pipe fits - their site says its 304 stainless but mine rotted off the car in less than 2 years
and Kakumei makes one - price is good but shipping is expensive also states 304 stainless but im not sure I want to chance this one either
Hi all,
J
What direction did you end up going? Im looking for HFC for my 03 FX45 since i had a cat just go out. Did you find a set that bolted on directly?
Thanks
