hybridshooter
- ohio
Hi guys I bought my 2005 fx45 a few months ago and it developed a "whomp whomp whomp" kind of noise from the front passenger side. I admittedly put it off longer then I should have due to life events. But it has gotten worse and louder. It does it at pretty much any speed, and gets louder and more pronounced when turning. I also have a vibration in the steering wheel at highway speeds. I jacked it up and checked the front wheels for up/down play and found none. When I grabbed the tie rod ends they are a little loose, as well as the endlinks. I know I will need to replace those, but don't know if they are responsible for all the symptoms I'm having. I'm about to rotate the tires to see if it makes a difference and will report back. I'm just look for ideas in the mean time. Also when sitting still and turning the wheel there is no noise. Thank you in advance for any help.
