FX35 Aftermarket Exhaust Roll Call
Thanks Merchant. For nismo with setup. How much in length do you have to extend the tip? or the G35 extension will just be enough without tip extension?
Will the Fujitsubo catback work with Kakumei Y-pipe? Anyone knows? Or it's better to go Nismo with Kakumei in terms of performance gain and fitment?
What is your definition of work...?? Cause the Kakumei Y-pipe has the exact same fitment dimensions as the OEM pipe and will communicate with any system on that way.
Only issue i had when i mounted the HKS legamax was that the kakumei was in a slightly different angle and made the pipe between the mid- and end-muffler hit a strut bar so we had to adjust that angle a bit. Further works fine :tup:
IMO, Nismo will work better with Kakumei. The collector on the Kakumei pipe is 3" in D, same with Nismo mid pipe diameter.. If you can keep each transition smooth (no big changes in D), it'll be better. If Fujitsubo mid is 2.5" then I suggest using a reducer for the Kakumei side of your extension while you're at it. Otherwise it'll be 3.0" => 2.5" at the flange.
Thanks EG. :.smile:
Greatly appreicated. :tup:
the fujitsubo is 76mm(3 inches) all the way through from y-pipe back.
