Fx35 06 is in fail safe mode pls help!!
yuri19782015
New Jersey
2006 FX35 AWD
Yuri
My fx all of a sudden started fail safe mode. My headlights stay on as soon as I turn ignition. Also my ac dont crank, fog lamps dont turn on wipers dont work, rear defroster dont work, side mirror dont work, fan stay on when ignition is on, vdc slip light on. I checked IPDM and looks ok. Fuses are ok. I need help pls to take it out this mode.
Is the motor down on power?
If you're referring to a Limp Mode, You should start by Disconnecting your battery for ECU reset. See if anything is resolved.
Hello. My motor turns on and car drives. I alrrady tried that and still nothing happens. Wipers, fan motor on all outside lights on. Ac compresor dont crank.
