ramoszx12r
- 2011 FX 50S
- Name
- Tony
It looks like no one make high flow cats for the FX. Have any one try using the 370Z or other infiniti high flow cats on the FX. I am looking on doing high flow cats ark exhaust and custom tune.
I was on the process of searching this site but there is a ton of material plus i am not familiar with the site.
Thanks for the reply and the pic. are the fx 50s have two cat per side or one.
i was thinking the 370Z high flow cat because they use the same frame right.
I live in jersey and the test pipe will not pass inspection.
I get a CEL eveyr now and then but just delete it and don't have a problem.
Jordan, do you remember the part # for the flanges you ordered from vibrant? I have test pipes but need the flanges.There are two, and the 370z/g37 would be the same - you'd have to make adjustments to either one to fit the FX50 please look at the links I gave you.
The test pipes will pass inspection as long as there is no CEL present when you get it inspected. Mine has passed with resonated test pipes since I put them in. I get a CEL eveyr now and then but just delete it and don't have a problem.
May I ask what method you use to delete the CEL?
You can just buy Vibrant brand flanges that are the proper diameter ant they will work. 2.25" I thinkThat would be great. Couldn't find in the thread.
