Front License Plate
RedMist
Massachusetts
QX70s
Hello Group-
I am need of some information on the front license plate mount for a 2016 QX70s. I need to replace the mount because when removing the license plate frame, I ran into a corroded screw that cutting oil would not help so I removed the whole mount but still couldn't move it. I need to replace the mount which is stamped Nissan 96210-1CA0A however some part filters on-line say it doesn't fit my car. I also I need to know if it is the correct part (or did somebody put on a different part because of a similar problem). Does the correct part (whatever it is) comes with clips and screws?
If it does not, what are the part numbers for the clips (2), the Philips head coarse screws for mounting the license plate mount to the bumper (2) and the Philips head bolt screw type bolts that attach the license plate frame and license plate to the mount (and car).
Finally, has anyone ordered an Infiniti part through their local Nissan dealer?
Thanks in Advance.
