Front brake popping noise
OEM pads lol.
Wayne and I were talking about maybe the distance control assist is making the pads overheat and cause excessive wear? If your behind a car the DCA keeps pushing the brake pedal down inside while I'm trying to give it gas. Maybe this is leading to the pads overheating? Possibly....
I would buy the shim and seal kits and rebuild the calipers. It is always good to do so anyway.
I would ensure that pads are properly positioned, the "clips" attached to them are correctly let so they push pads off the rotor when the piston is retracted.
Sent from my iPad
