eJay
- Fairfax, VA
Hey guys, so I just installed the H&R springs and during the process, I over-tightened the inner nuts of the front caliper mounts. These are the nuts that you have to hold onto while tightening/untightening the caliper mount bolts from the inner side of the wheel-well. The upper two nuts (one on each side) tighten fine but when I try to tighten the lower nuts, the bolt keeps on "tightening" without much force. I am wondering if I can replace these nuts without replacing the entire caliper mount. If I can, could someone tell me the size and location to get these hexagonal nut?
Thank you in advance!
