Ok, I developed the same problem - my passenger fog assembly was damaged by road debris. Shortly after the damage occurred, both fogs quit working. I replaced both fog assemblies (a real PITA) and they didn't work.
I downloaded the lighting system service manual and began by checking the fuses. While I was in there, I even replaced all of the fuses with the ones that light up when blown. All fuses checked out OK.
Still no lights, so I started the test procedures with a multimeter. Right off the bat, noticed that there was no voltage at the wiring harnass, so I traced back the wiring. All of the wiring looked fine, and it is properly grounded. I did some additional tests and I think I have narrowed it down to the most likely culprit being a bad Front Fog Lamp Relay.
(Rant: I hate having to remove so much stuff to access a fuse panel, and it is really tight working in there!)
So my question is, where can I buy a new fog lamp relay and which model do I get?
When you look at the IPDM E/R panel, there are three relays on the far right side at the top. The first one is a throttle control motor relay, the second one down is a fuel pump relay and the third one down is the fog lamp relay. These three all look the same (black), and I presume that they are the same type of relay. There are also two additional relays down below under the three cooling fan relays...one is sky blue (left fog) and the other is white (right fog).
I am guessing that I probably only need to replace the black relay up top. Thoughts?
I did a lot of internet searches but could not find a place to get a replacement relay. There are Nissan relays out there, but they are mostly for Altimas and not my modek year (2005). Anyone know where to get one? The local parts store(s) don't have anything close.
Final question is...do the relays just pop out of the IPDM Terminal box, or is there a special way to get them out? I tried pulling the fog relay to examine it but it was securely stuck in there and I don't want to break anything.
Thanks
