Fitting new actuators
AconsteDani
Romania
Fx35
Hello !
So, I need to replace the actuators , as the factory ones died.
Purchased 4 actuators , and now time to mount them.
Usually I read about a g35, but on the fx, things are a bit different.
Also, I found another fx on this site but it has different colours when it comes to the wires...
So, the actuator has 1 blue and 1 green wire.
The cables in the door are black, white, purple and yellow..
How should I wire them ?
connecting them backwards won't hurt anything - they'll just lock when they should unlock and vice versa. So connect the wires and test the function. If it's wrong, swap me and you're good to go.
OK, but I should connect the green to the purple and the blue to ?...
Just finished with this fix on my '03's front right passenger door. I have the same exact wires as you and aftermarket actuator. I used the purple and yellow wires. From the actuator, I connected the blue to the purple and green to the yellow. If the action's opposite, just switch the wires. Let me know if it works!
