My dashboard lights all triggered as well while installing the GROM. I was able to reset ECU by turning the car on, counting to 3, pumping the gas 5 times, then counting to ten, then holding the gas pedal down for ten seconds, then releasing, counting to ten, then holding the pedal down another ten seconds. I was also able to reset the airbag light by turning the car on, then turning it off the second the air bag light blinks off for the first time (turn off before it blinks back on). Repeat that process 4 times and airbag light will stay off. I reset the TPMS by putting a different pressure in each of the four tires (I forget the exact psi but can be found online easily - I would post a link but I'm still an Infiniti scene newbie so I can't). I then removed the lower panel (by drivers left knee) and grounded the wire found there 6 times. The only light I can't reset is the amber light that says "key" if anyone knows a DIY trick to reset this, I would love to know it. Thanks.
