Engine Damper
my 2 cents...
1) I would presume the mounts points will be different.
2) engine dampers reduce the amount the engines "lean" while reving to get that extra bit of torque. I have noticed but does the FX move that much?
3) you can also get solid engine mounts. not recommended since it will make the car vibrate. If only used for racing than ok I guess.
4) why not, if you can make it fit, at the very least , its a engine dress up.
