Double check wheel specs
dragonh
Taiwan
2005 FX35 AWD
Hello everyone...This is the dragon from Taiwan..Just wanted to double check the wheel specs for our FX before ordering.
Firstly the size. Would I order the 22x9 22x9.5 or the 22x10 secondly what offset would I need if I want them to be flush and not rub against the arches 30 35 or 40..as I am already lowered with my custom suspension kit..I have American Racing Burn 337 22inch at the moment but they stick out abit and rub against the wheel arch so I can't lower too much which I really want to do.
Please kindly confirm the specs so I can order..Thanx guys!!
Regards,
The Dragon
Depends on the offset of your wheels, all of those will work depending on the offset you choose and the tires. For 22in wheels you will want to stick with 30's to stay within the overall oem diameter and keep the AWD system happy.
basic rule is you can add ~+25mm offset , farther out then stock. use the offset calculator on this site, under "member tab" on top of every page.
ie. 9 inch rim 25 mm offset = 28mm more rim outer edge (position of outer edge of the rim).
