QX70 09+ Door won’t open
Discussion in 'QX70 Exterior' started by Alex Betancourt, Jan 5, 2018.
  1. Alex Betancourt
    Alex Betancourt Member
    20
    7
    Bayonne, NJ
    Car:
    2009 FX35
    Name:
    Federico
    So it got very cold here and when I tried to open my driver side door I must’ve pulled too hard and now the door won’t open from the inside or outside! How can I get the door open now? When I hit the key fob I hear the clicking but nothing happens.... pls hellllppppp.
  2. Pinstripe
    Pinstripe Member
    198
    62
    Canada
    Car:
    2013 FX37
    Same thing happened to me. Dealer had to replace a part - sorry don't remember what exactly is was, this happened last year.
  3. OP
    Alex Betancourt
    20
    7
    Bayonne, NJ
    Car:
    2009 FX35
    Name:
    Federico
    I really don’t feel like going to the stealership for this issue. I did however purchase an aftermarket warranty a few months ago. Going to call and find out if this would be covered. Don’t want to have to dish out $500-$600.
    Sent from my iPad
  4. Kanedean
    Kanedean Premium Member Premium
    335
    34
    Peace River, AB
    Car:
    2013 FX37 AWD
    Did you get this fixed?
    This sometimes happens to me after a car wash, when it gets really cold, and only after I use the aftermarket remote starter. For me, one of the security function in the door latch is frozen. I just use a heat gun to heat up the door latch area. You'll hear a click and the door will open. This issue happens for both the front driver and passenger doors. It has never happened for rear doors.
  5. OP
    Alex Betancourt
    20
    7
    Bayonne, NJ
    Car:
    2009 FX35
    Name:
    Federico
    I dropped it off this morning at the stealership. Awaiting that call... lol
    I have a third-party warranty so hoping to covers something.
    I think i may have tried almost anything and everything. I wasnt about to rip out my the door panel in 20 degree weather and mess something up.
  6. Kanedean
    335
    34
    Peace River, AB
    Car:
    2013 FX37 AWD
    So... the temp dropped to -38C this morning and my driver side door had the same issue again. My trusted heat gun method worked once more.
    Keep us posted to see if there is a permanent fix for this door issue.
  7. OP
    Alex Betancourt
    20
    7
    Bayonne, NJ
    Car:
    2009 FX35
    Name:
    Federico
    The stealership was able to open the door with the manual key.. they greased up the door hinge and what not. I picked it up and the next morning it did it again. I tried doing the same with the key and it worked.. i did notice that since it got warmer here (40-45 degrees) it has been working fine.
    They did charge me $135 for a diagnostic fee. But then wanted to charge me $566 if i went back to change the actuator since thats the cause.
    The cheapest i found the actuator was around $300 online and its for an OEM one.
    Seems the culprit it very cold weather.
  8. Pinstripe
    Pinstripe Member
    198
    62
    Canada
    Car:
    2013 FX37
    It's been below -20C/-4F here for two weeks and no problem since I had the part replaced. The cold is making the problematic part known, but it's not the cold per say.
    That's wind chill right? I sure hope so! Remember that wind chill does not affect machines, they only 'feel' the air temperature.
  9. DatMan
    DatMan Member
    687
    135
    Ottawa, ON
    Car:
    2007 FX35 AWD
    Name:
    Dat
    There's a guy on here that sells generic door actuators and does a full HOW-TO for the install for about $120-160 for ALL 4 ACTUATORS...
  10. Kanedean
    335
    34
    Peace River, AB
    Car:
    2013 FX37 AWD
    No, that's straight up the temperature.
    DatMan likes this.
  11. DatMan
    DatMan Member
    687
    135
    Ottawa, ON
    Car:
    2007 FX35 AWD
    Name:
    Dat
    Spoken like a true Canadian! Ottawa has had a WEIRD winter this year! How's the west doing?
  12. Pinstripe
    Pinstripe Member
    198
    62
    Canada
    Car:
    2013 FX37
    Worse we’ve seen here in Montreal is -31 before the wind. It’s a brutal winter for sure.
    DatMan likes this.
