you are the first to tell me why it will not fit. i always got the replies: no it will not!
thanks for the help. since FX45 is really tough to get, i still needd to explore it more. if the accessories are the only problem, can't it be solved? like using the M45 with it's own accessories, or alter the brackets of the accessories to fit. anything else is a problem or only the accessories? what about the atarter?
basically M/Q45 and FX45 uses same block and heads? as much as i read, they are all VK45DE, right?
thanks for the advice guys...
BTW- LS is a great engine, but swapping both engine and tranny with harness, ECU etc, is above 8000$ for low milege combo...
---------- Post added at 01:00 PM ---------- Previous post was at 12:58 PM ----------
BTW- any other members here using FX45 and happy?
