Hi just changed the rear axle fluid on a 05 fw 35 rwd using mobile 1 75\90 LS fluid. got 2 qts of it ( have about 5oz left over) and just wanna make sure they way i did it was fine. I used my boats pump but swapped out the hose and this one actually fit almost to tight. when i seen it seeping from the opening with the tube in there i pulled it out and let it get to around the level of the bottom of the fill hole. it was still at a slow drip and i plugged it. that should be good right ?
