Did anyone else experience Display going out when it's hot?
Max_Spd
Northern, VA
2007 Infiniti FX35 Sport
Hey guys I recently noticed that my display occasionally turns whiteish when it's hot out!
My reverse will work, but the actual navi/radio display when switched on will still remain white, until it cools down and I restart the system (turn off/on the car)
I wanted to see if anyone else is aware or had issues, is there a recall on this or...
2007 FX35 Tech/Navi
Thanks...
Mine flickers once in a while. It's never gone white though. I've diagnosed mine as a loose connector somewhere, just not sure which one yet. When I check and tighten all the connectors, it's fine for a while, then it'll come back a few months later. But I've pulled apart and reinstalled the wires so many times, this was bound to happen.
Maybe the heat is causing one of your wires to make contact with something else. There are a lot of wires back there and a lot of bare metal, so if one connector was damaged or a wire loose, heat could affect it.
The thing is that I dont think its related to the connector as much as something internal to the unit and the board, I had this issues since last year, this entire winter not a single incident, due to low temps, but once the heat came the problem came back! I get lucky sometimes that the unit comes back mid drive. So I feel there is some board that i should do something in regards to heat isolation or maybe install a 9-12volt fan similar to a PC, I am just not sure which of the module boards is responsible for the video output from the Radio/navi. Again the reverse is on a different channel and works with the white screen no problem!
