Dallas area shop to replace shocks
anon1000
United States
Hi - anybody in DFW area have recommendations on an affordable shop to replace the shocks on 2004 FX35, all quotes that i have got are for 8hrs of labor. From the DIY looks to be much shorter job..
Rear?
They are easy. I did my coilovers install at home in the garage with zero previous suspension knowledge. I used the diy I found on here
DIY is the way to go. Since you mention "shock" we assume you're only replacing the rear shocks? If so, at leisure without any prior suspension experiences and you can turn some sockets and hand tools, you can replace the rear shocks in 3 - 4 hours. One advise if you plan on doing it yourself is to spray the two 12mm nut that hold up the top end of the shock a few hours ahead or overnight. If you broke or strip those two nuts, it will co$$t you more to get them repaired since the two bolts are weld to the body.
