thumper300zx
- Utah
- 2003 FX35
I had to get under the car to replace the rear camber and toe adjusted bolts. You have to remove the center-mount bolts for clearance on those. You also have to remove a couple plastic splash panels to to get to the ASB bolts. While removing the splash panel bolts, they pretty much all busted off (the bottom side of the entire car is a rusted mess). But worse, removing the rear-most 10mm bolts, a very large portion of a crossmember that sits between the gas tank and the rear suspension completely broke away -- the bottom side of that whole crossmember is rusted out, very crumbly and easy to break apart. I'm not even sure which part it is from a diagram, but I'm assuming it would be quite a PITA to replace. Anyone have experience with this kind of stuff on an FX35 (2003)? Nightmare...
I was thinking maybe it was:
[TABLE="width: 100%"]
[TR]
[TD="class: redText, colspan: 2"]74510 - BOARD ASSYREAR FLOOR [/TD]
[/TR]
[TR]
[TD="class: part, colspan: 2"] Part Number: 74510-CG000 [/TD]
[/TR]
[/TABLE]
http://timdahleinfinitimurrayparts....01&partnumber=Part+Number&description=Keyword
---------- Post added at 04:08 PM ---------- Previous post was at 03:42 PM ----------
Here are some pictures...as I said, it's between the rear suspension/axle and gas tank. I'm thinking it's probably there for protection more than anything. Doesn't seem horribly important structurally. You tell me
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
