COPPERFX Updated Pics
After I had my front air deflector for a couple years, it developed some internal cracks. One day I decided to paint it to match the bumper trim - flat just like your grill. Came out much better than I expected it to - the flat black balanced with the lower bumper and the deflector looked new again.
Since then my painted deflector took a road debris hit and broke so I have a new one - but I plan to paint it also ... maybe body color...
Your engine bay is so clean - love it. Think I'll get that Weapon R tank for my power steering reservoir. Hearing it didn't take special brackets is what convinced me.
For the coolant tank:
1) remove stock tank and plug line.
2) bend stock bracket down and out of the way that way you can reuse it later if you switch back.
3) drill hole in fender to accomodate a bolt + washer + lock washer + nut
4) install and tighten weapon r coolant tank
5) the mounting tab has enough bend to adjust as necessary to level the tank out
6) top off fluid with oem reccomended coolant
7) clean up your mess and your done
8) great little $60 mod
