Coolant bleeder valve
Crankor
10 FX35 AWD
I started having some overheating issues where my coolant just dissapears. Today i saw after filling it up that it immediately was leaking some on the ground once i started it up and without being able to see much in the back area where it appears to be leaking onto the downpipe, I'm assuming its a broken coolant bleeder valve. Thing is, i can't find it.... I feel like i remember seeing one when i swapped out the valve covers (i should have changed them then) but now where most of the videos show where it's suppose to be, i just have a solid hose on the drivers side (see pic). The looks like here might be one on the passenger side but it looks smaller (assuming it was replaced) so i'm not exactly sure if that is it or not. Isn't there suppose to be 2?
Mine doesn't have it on the driver side either, and it does look like the other side has been replaced on yours.
I found these for drivers side, its a known BIG pain to remove it and replace it, as there is no room for leverage on it.
good luck
Ravi
