Daniel954
- Broward, Florida
. As I am accelerating I hear a prominent clicking noise between speeds of 5 and 20(so far) that goes away on the highway. What is causing this?
if its coming from the rear, then its ur axles that need greasing, if its from the fronts might br ur sway bar bushings
:rotfl:Is it a SINGLE CLICK at a random speed between 5-20mph or CONSTANT CLICKING below 20mph?
The rear of mine started clicking on deceleration and acceleration also when switching from reverse and forward only after I changed my brake pads. Thought it was the brackets which I did replace. Replaced them again still made the noise. Replaced the brakes and hardware again. Noise still there. Scratching my head. Thinking it could be axles but why after changing pads and not before?
Yours is probably the axles. Grease those bitches. Not sure why it would happen after the pads. Maybe coincidence, maybe you just noticed it then?
