95maxrider
My 2011 FX50 decided to stop recognizing the key fob after I drove home from the store, and I'm getting the red "no key" icon when I get in and try to start the car. Installing a new battery in the fob didn't help, and I can still lock/unlock the car from a good distance, so that part of the remote seems to be working fine. Seems like the most likely culprit is the electronic steering lock module, but I'm not sure if the symptoms actually point in that direction. I tried tapping it with a hammer but no luck.
Notes: The steering wheel is locked when I get in the car, and it unlocks when I put the car in On/Acc mode. To me, this sounds like the lock module is working correctly.
Can I just swap in a different steering lock module, or does it require reprogramming? If it requires programming, I wonder if I can just swap the motherboard from mine to a working unit to avoid programming?
Or does this sound more like the intelligent key module or BCM is going bad? When I put the fob in its holster in the dash, it doesn't light up like I think it used to do.
When I lock the car the red "no key" light flashes again. I do not have a second fob to test with.
