- Westminster OC
- car
Cams usually move the powerband to the right, so reving higher is a good idea to make the most of the cams. Valvetrain should be fine til 7k or so, if you are doing the work yourself might as well consider doing a high compression pistons and replacing the rods.
Parts even if you are doing the labor for free is going to rival a vortech which will still yield more power. G/Zs struggle to make 300 whp na, a vortech even with the smallest pulley will make over 300 easily.
