Hello,
This will be a bit of a kick in a Infiniti direction. New here but have owned my car since nearly new, (5000 km).Its an Fx30dS.
Bought at a Infiniti center, always serviced by Infiniti until 2020 when it is impossible mental for me.
Now, I have had the same break issues for litttle more than 15 months. (I have also have squeeking brakes in the rear for 5 years that NO
Infiniti Factory has managed to fix but thats a diffrent story i have written of to fix, its a permanent bug and a consumer pitch from Infiniti to me now when
Im thinking of what family hauler im to buy next) I also have a few other issues that are pure quality issues.
I relocated so I had to leave my Inifiniti Center Berlin, Germany during 2018 so I was sadly forced to change infi center factory.
I have changed discs and pads 3 times during this period, also a set of wheel barings in the front. it eats a set of discs every 5000 km.
I have had in at an official Infiniti Factory who said its the discs, twice. so they changed, same result...
I drove another 6000 km this summer so I need to change again....
After digging and asking around with factoris in UK and Germany I will try myself.
I will:
Take away all the old parts.
Brush and clean EVERY thing with steel brush, shaft hub, wheel hub inside of the rim.
Install a caliper renovation kit (Put on new guide pins,bolts etc,) and then
back on with the new discs and pads.
According to experienced mechanics it might be not cleaned (rusty) surfaces
in combination with bad guide pins that is cuasin the vibration.
All You that have vibrations, try and drive the car and break as is written before above, then clean
the inside of the front rims thouroughly. Repeat the procedure and feel if there is a difference.
In my case I can feel the dirt on the rims give me more vibrations.
I will be back with reporting when im finished with the change, Im an enthusiast of another german produced sports car. I must stress I get completely surprised over the
incompetence and low level of knowledge of the mechanics in the Infiniti Center Facories outside Germany so far. A pure joke!
I have written to Infiniti Europe and pointed this out after my experinces. The only answer I get is a recomendation to go back to the factory again and let them fail again.
The only things they have been sucessful with is keeping my car for a long time...
Parden my bad english spelling.
