I don't need to press it more than once, but I feel like the brake pedal travel is greater at the beginning? It usually goes like this, during my first brakes of the day, I depress, the shudder/skipping/noise/judder happens and I depress, and press again. However, if I don't depress and continue pressing it will brake-but I feel like it is skipping like the almost abs feel i described in the original post with less than maximum stopping power. And than it travels less as it builds up-I cant really confirm this but I feel like it? Im not sure where you got the idea I was doing a new brake line install. definitely not the case. was already stupid enough to buy pads without checking them because I was "sure" that was it but obviously not, so Im not trying to go around replacing components until I know. do you think bleeding the system is worth it? It is getting really bad these days and I need to fix it ASAP!
