- Portland, OR
Can anyone tell me where the factory amp is located?
It's inside the subwoofer enclosure, atop the spare tire.
Have you tried listening back under the rear floor pull. Put your hand on it to feel for vibration. If it's not working you should be able to tell. Listen popping or distortion. That would prob happen first before cutting out. Kinda sounds like a loose wiring harness or wire fiber break somewhere in the factory amp feed for the sub. Hopefully your stock amp isn't going bad, that would be the next step.
