- Austintatious, TX
- Name
- Sj
the whole car actually.....What the hell happened all of a sudden?
all fine until last night but this morning after doing the shifter panel upgrade, when i started the car, it acted strangely. i let it run on idle and that's when the car started vibrating suddenly for a second or two, the engine would seize a little bit causing the vibration again and then normal again, more like a car being turned on with the MAF sensors unplugged. rpm wasn't jumping randomly though. i tapped on gas a little bit and it revved as normal but then again on idle..same problem...
Also, I filled up the gas tank 3 days ago but the needle only showed 3/4 of the tank, what's up with that?
as for the booty shaking...
