BMW 335 (N55 Engine) - Any prior owners?
pmanliu
iS VIP
iS VIP
NYC
2017 WRX
Hey all,
So i'm considering getting a 2011 model year bmw 335 x-drive with the M package (aesthetics). Just wanted to see if there were any prior 335 owners on here who can shed some insight on how this car performed from a reliability perspective? I already posted on a bmw forum but of course may get biased opinions there.
From research, it looks like the pre-2011 models (n54 engine) had major issues with the fuel pump. According to the message boards, the 2011+ models with the n55 engine took care of the issue. Are there any other issues I should be weary about?
Thanks!
Find a CPO or one with a warranty. Do not buy one without. So many stupid things might go wrong on your car that will cost you thousands. Just to change bushings are in the hundreds. I love the 335 but are you looking for the E90 4door or E92 coupe model? I would get the 335is for the double clutch tranny with launch control,other than that i havent seen any major issues on these models. Also get a 2011.5 model, alot of things changed on the M3 models so im assuming it might be the same for non M's
I had a guy at the firm that had a 335 and his car would always be at the dealership for a whole variety of problems. He was so glad he was under warranty. He vowed never to buy another BMW again....
I know my friend had lots of issues with the N54, as did most who had any issues. It was sad because he pretty much never drove it when he was in town from school as it was always getting repaired.
i have a e90 328i with the n52. with the 4 years i had warranty it was great. after that not so good. i had 8k invested on a engine sensor maltifunction. i had 4 spark plugs gone and an ignition coil blew up at about 50000 miles took 1k out of my wallet. Many more problems i can name but these were pretty bad.
---------- Post added at 07:34 AM ---------- Previous post was at 07:33 AM ----------
i would rather shoot for an infiniti g sedan if ur looking into a sports sedan. its the wiser choice in my opionion the e90post has some good people too.
Thanks for the advice all. My target car would be a 2011+ n55 335 Sedan (AWD) w/ M package.
From e90post and other bimmer forums it looks like the n54 is a hit or miss in terms of reliability. So far the n55 has been pretty reliable but other things (e.g. electronics) may crap out after the warranty period. Seems like a pretty big gamble, but I'm not in a rush either so going to do some more research. You know you're taking a risk when people on the bmw forums are steering you towards other sport sedans.
My boss owned a BMW he stated that because of all the issues with it he would never buy another one. He had a 335
N54 had issues like high pressure fuel pump, wastegate rattle, water pump, injectors, carbon buildup and some other minor stuff. The engine itself is basically bulletproof, it's just that much like most other German automakers, BMW over engineers stuff and the complexity of the electronics is what gets you. My '07 is relatively low mileage at 44K and no major issues for me. I'm well out of warranty but don't have any real hesitation about driving the car, I'm not afraid it's going to strand me. I get random error codes like bulb checks, but nothing that I worry about. A lot of the N54 stuff had extended warranties on like the turbos and HPFP so most of the lemons were fixed.
N55 fixed most of the N54 issues, but it's also limited in terms of power potential. If you don't plan to really mod, it's fine, but the N55 went down to 1 turbo from twins. And the N55 has VANOS issues, I'm fuzzy on the exact issue, but they can fail and that can strand you. Also, they have the same electronic water pumps that N54's have and basically all BMW's. It's not a bad thing in that the water pump is really advanced and can stay on while the car is off to cool off the turbo after driving. But unlike a belt driven pump, when it fails you're stranded. There is no real warning, it's fine one second and then the next you've overheated and call the tow truck. It's not as common as some say, but I would be mad if/when it happened to me.
Maintenance isn't bad if you can do it yourself. Parts aren't any more than the FX and it's not much more complex. There is much less room to work since the engine bay is a lot smaller. And BMW basically makes you remove everything to work on it. Last year when I had to replace my AC condenser due to a leak (aftermarket oil cooler punched a hole in it) I had to pull the bumper, intercooler, radiator, fan, engine cover and a few other misc. parts just to get it out. On the FX, there is so much room I could have just tilted the radiator back and slid it out. But for maintenance stuff like spark plugs, it takes 30-40 minutes just like the FX and no longer for an oil change.
Is the BMW annoying? Absolutely! But for me, it drives so incredibly well that it's worth it. Of course I haven't been stranded by my 335i yet or taken it in for a major repair, so maybe my attitude will change then. But if I would sell the FX before I sell the 335. FX is more reliable, but the driving experience isn't the same. I will probably replace the FX with an X5M when it comes time.
And I'm guessing you're replacing your IS w/ a 335? FWIW, I had an '06 IS350, got it a month after they came out. I loved that car, it was fast, handled well, was comfortable, and super reliable. I will say that other than reliability, my 335i is better in every way to me. It's faster and just drives better. Transmission shifts quicker, the paddles actually work and steering feel is better. The only thing about the IS350 that I miss is that I never once thought about reliability. I knew it would always run perfectly. BMW is way more temperamental.
