Bluetooth problems with myTouch
I am able to pair up with my TMobile MyTouch phone, and i'm able to answer or hang-up the calls by pressing the "button" on my steering wheel. However, both speaker and mic won't work though, i still have to talk thru the phone. :frown:
But i dont' have this problem with my blackberry though. It works perfectly fine with it, so I'm looking for some quick pointers here. :cool:
---------- Post added at 12:12 PM ---------- Previous post was at 11:01 AM ----------
bump
If that's the case, I doubt its the BT function of the FX. It is most likely a feature of the Mytouch phone. I would look under the options in the phone.
hmmm...my phone works fine with a regular BT headset, so why would it need re-configuration to work with the FX35?? It should see/pair up just like it does with a regular headset, shouldn't it??
Well I am just pointing this out because you said that your BB worked fine with the FX so it most likely is an issue with the phone configuration. I would look in the properties of the MYTouch BT connection
