I had the same issue with my fx45 at around 92,000 miles.
Blue smoke every start up
I had the dealer do a leak down test for me cause it was still under warranty
numbers came back with under 2% pressure loss on all cylinders.
Now leak down tests can never show valve seals so when I got the truck back I drove it for about 50 miles or so then parked it.
The next day I removed the intake manifold to find oil pooled up around the top of a few intake valves but there was also oil in the manifold
So I removed I removed one exhaust manifold and found no oil on the exhaust valves which lead me to believe there is an issue in the pcv system.
The first thing I did was add a full bottle of seafoam to the oil and I drove the car for about 2k miles and changed the oil
Then I did the Seafoam treatment on the intake manifold and added one bottle to a full tank
At around 175000 I deleted the pcv all together no catch can just open crankcase with filters
I am now at 183000 miles and I have no blue smoke
the seafoam in the oil also remedied the chain slap noise
Every other oil change I add a bottle of seafoam to my Mobile1 synthetic about 2k miles before I change the oil and filter
the isopropyl alcohol and other additives break down carbon build up with ease.
when I drop my oil pan and replace the valve cover gaskets in the spring I will show you pics of how clean this beast is with this many miles on it.
I will also post pics of my compression test results
I have found that if you are near the end of your warranty the stealerships try to convince you nothing is wrong
but when you bring it in for an oil change after the warranty expires they tell you, you're gunna need a valve job and a new timing chain.
Don't ever believe their crap until you figure it out for yourself.
Any write-up or more detail on the PCV delete?
My FX45 blows blue every morning but no real use of oil or running issues. Planned on trying the catch-can and then found this post.
Any info appreciated - Thx
