black emblem
yeah not hard at all but make sure the paint is fully dried and cured because you will need to aplly pressure that will leave fingerprints to reattach. also take time when using the double sided tape because this will affect the look because the double sided tape is a little bit thicker than oem.
What's the best way to cover the rear fuji emblem with vinyl and all chrome pieces in the trunk? I'm thinking of doing it instead of paying to get the pieces painted but I'm not sure if the chrome pieces must be removed or can just be wrapped.
You better remove those pieces, will make the job cleaner and a lot easier. You need to remove the inside plastic trunk lid cover and unscrew couple bolts that holds those pieces. You will also need the trim removal kit to pop them off after that. Emblem just glued, no bolts
