Belt tension
InAnFX35
Decatur IL
I recently replaced cracked A/C and power steering belts and now the power steering belt squeaks when I crank the wheel all the way. My question, is there a way to determine proper belt tension without using a belt tension gauge?
It should be tight to the point where you can push it down maybe only half an inch with your finger...that's it.
