The rear feels softer than the front because the spring bucket is mounted pretty inboard relative to the wheel. So the forces seen by the wheel get multiplied by the distance to the spring. It's why the rear spring rate is higher even though there is much more weight on the front of our car. It's also why the rear seems to blow through the travel. 400lbs of force at the wheel probably equal 800lbs at the spring or more. So that's why a lot of people who track their Z's, G's, or any car with similar suspension design where the spring and shock are separate get "true" coilovers where the spring sits on the shock and it mounts outboard by the wheel. You can run lower spring rates and get better handling.
But since that's really not an option for us, basically our only solution is to run higher spring rates or more damping. Increasing damping has the negative side effect of changing both compression and rebound damping. So while I've maxed out the damping and it helps keep the car from rubbing/bottoming, it also slows down the rebound so much that if I hit a washboard, the car effectively has no suspension travel. Hopefully once I get the higher rate springs, I'll be able to crank down the damping a touch. As a disclaimer, I don't suggest people do what I'm doing. It is not good for performance, but it helps keep me from messing up my fenders and tires.
