- FX
judging from how slow the springs and coilovers are being developed for the 2ndGen FX, I think it wouldn't surprise me if ANY camber kit is EVER developed....
+1
Tony, let us know how your tire wear is when you check them . When you get all that extra power, you are going to have enough problem putting the power to the road.Hard to chew through my tires when I never really have my car. In the past 12 months, she's been gone a total of 6.... Iv blown a tire, but have yet to shred them down. I'll check them out once I get it back to see how things stand now. Iv got something going with Megan racing for some potential coil overs as well for all of us, but won't know anything until I get my car back & get it over to them. Megans based out here in SoCal, so I'm hoping working with them will be easier. I also thought that about Eibach, & we all know how that turned out.....SMH!
It would really be BS if we all waited this long to ride lower just to have the side effect be that we blow through tires every 10,000miles! I only average about 10k with tires without having that issue, so I REALLY hope we find a solution. Fingers crossed on BC (I'm down for a group buy if the terms are right) or Megan racng coming through for all us 2nd Gens!
if you guys REALLY want this, I'd say you are going to have to pool together & get a fabricator to custom build this for you... the investment will be in buying original control arm(s) to fabricate a jig, then produce custom adjustable arms... it's not very difficult to do, but requires a fairly significant initial investment... split between a group should be very doable but don't expect it to be dirt cheap... how bad you want it? a fabricator is going to want to see a certain # of orders for it to be worth tooling up for this & building a jig but were talking something that really isn't so difficult to build either really... the first one would cost a lot but then each copy after not so much, the more pieces you do the less each one actually averages out to cost...
it also might not be impossible to modify an already available adjustable aftermarket existing upper arm from a G maybe too, but this too would require the investment of buying it & seeing... someone is going to have to have a hand in developing this one way or the other... would be great if a company did it on there own but that also may never happen...
:top: That was my plan if the Kido coilovers going to give me a significant negative camber.don't you have non directional tires? either way you can rotate every 3,000 miles and you'll be fine.
I can't see you slamming it anyways, only a few inches to get rid of that gap. Didn't read the whole thread, but I don't think you'd be that much out of OEM specs unless you go Aero style slammed.
| Infiniti | Year (From-To) | Drive Type | Alignment | Rear Camber | Rear Camber Tool | Rear Toe | Rear Toe Tool | Thrust | Front Caster | Front Caster Tool | Front Camber | Front Camber Tool |
:smile (2): Slam is not my style, maybe another .5" lower than the H&R springs are now....it will be hard not to lower it some more since I have the feature is there with coilovers.
ST 2s are directional so I would have to re-mount and re-balance every few months.. I would like to drop it around 3; the camber and toe on the springs looked horrible with the 1.2 drop, I can only imagine what a 3 would do.
Galaxy S2 on
