ADJUSTING BC COILOVERS (PRELOAD)
TOOLS:
SUPPLIED SPANNER WRENCH’S
SAFETY:
ALWAYS USE QUALITY JACKSTANDS WHEN WORKING UNDER YOUR VEHICLE.
NEVER WEAR LOOSE FITTED CLOTHING AROUND A RUNNING MOTOR.
ALWAYS WEAR SAFETY GLASSES.
PLEASE STAY SAFE.
1. RAISE YOUR CAR ON JACKSTANDS AND REMOVE THE WHEELS.
2. CLEAN THE COILOVER THREADS WITH COMPRESSED AIR AND A RAG BEFORE MOVING THE LOCK RINGS.
3. LOOSEN LOCK RING (B)
4. LOWER SEAT (A) SO THAT THERE IS NO TENSION ON THE SPRING.
5. NOW RAISE (A) BY HAND UNTIL IT TOUCHES AND HOLDS THE SPRING FIRMLY IN PLACE WITHOUT PUTTING TENSION ON THE SPRING. (THIS IS KNOWN AS A 0 PRELOAD).
6. RAISE (B) UNTIL IT TOUCHES (A).
7. TAKE YOUR SPANNER WRENCH AND RAISE (A)(WHICH IS NOW PUTTING TENSION ON THE SPRING) UP 5MM (TOP OF (B) TO THE BOTTOM OF (A)). THIS IS KNOWN AS A 5MM PRELOAD (WHICH IS WHAT BC RECOMMENDS FROM THE FACTORY).
8. AFTER YOU GET YOUR 5MM PRELOAD RAISE LOCK RING (B) BACK TO (A) AND TIGHTEN THE TWO TOGETHER.
9. YOU ARE FINISHED.
TOOLS:
SAFETY:
PLEASE STAY SAFE.
