Battery Replacement
Hi Everyone!
I am new to this site and actually new to blogging for that matter. I have an 04' FX35 with only minor upgrades (Stillen Cold air intake with Z-tube).
My Battery just died on me this morning and I will be replacing it. Anything I should know before making the change?
Have a quick read here, but there is nothing to it really.
///3647
And welcome to the Scene!
Thanks Dr. I wonder how they change the battery with the car still on? In all my years in autoshop I don't think I ever tried that! By the way, your car looks sick!
I don't know either. When I replaced my battery I just did it in the autozone parking lot. 10 min later I was done.
ELECTRONIC CONTROL UNIT DAMAGE CAN RESULT
FROM IMPROPER BATTERY CONNECTION​
APPLIED VEHICLES:​
All Infiniti
SERVICE INFORMATION​
The vehicle 12 volt battery is an important part of the vehicle electrical system and is required to stay
connected when the engine is running.
To prevent damage to vehicle electronic components follow the instructions / cautions below.
IMPORTANT​
: Damage to electronic components (ECM, TCM, BCM, etc.) due to improper battery
connection will not be covered under warranty.
CAUTION​
Make sure the ignition is OFF during battery service and replacement.
Do not disconnect or connect any battery cables while the ignition switch is turned ON.
When disconnecting a battery, always disconnect the negative cable first.
When connecting a battery, always connect the positive cable first.
Do not leave a battery cable loose. Tighten battery cables immediately after attachment.
If a battery cable is loose, do not operate any electrical loads.
(This includes turning the ignition ON, starting the engine, operating accessories such as the A/C
system, power seats, interior lights, exterior lights etc.).
When “jump starting” or “boosting” a battery - be careful. Don’t accidentally reverse the polarity of the
cables.
